Sagging headliner
Old Mar 22, 2015 | 05:33 AM
  #51
OffroadFrance's Avatar
yeah I was wondering about that. Most I have done before are pretty straight forward. This one looks like a bear.
It can be 'très difficile' AR. It really depends on the quality of the new headliner material sandwich and the prep of the grp backing. The spray adhesive is critical and I've used 3M's glue, not cheap but good glue. It's best to do the fitting in 2 halves not attemp it in one mad panic. Lay out the material on the grp backing to ensure it's central allround with it pushed roughly into shape then fold back the half you are going to stick down. Ensure you have good quality tools, craft knives, scissors, rubber and wood/plastic seam rollers, ball shaped rollers but most of all ensure they are all spotlessly clean. Make sure you have the adhesive remover for any errors or clean ups and also have a supply of medical type latex gloves which are better for grip and keeping everything clean. Have fun
Old Mar 22, 2015 | 02:00 PM
  #52
Jnj's Avatar
Jnj
I give up on installing this fabric. Ripped everything off. Sometimes it's best to just pay the pro's. Ordering 3 more yards and will take it someplace.
On a positive note during the time I thought the glue was tacking I replaced my passenger window motor so that's good haha
Old Mar 22, 2015 | 04:54 PM
  #53
Hi, it's a difficult task and sometimes better left for the pros, in recognising this is half the battle. Removing and replacing the headliner is probably the greater part of the job so relining of the grp should be relatively inexpensive. Might I suggest if you have sunroofs it's a good time to ensure they are sealed properly and the drain tube spigots aren't broken and are secure.
Old Mar 22, 2015 | 05:02 PM
  #54
Jnj's Avatar
Jnj
Taking the headliner out was easy. Putting it back in will be just as easy. It's gluing this foam backed material proving to be difficult. If I had used a regular piece of cloth or painted it I would be done by now.
I have inspected my drain tubes and no problems with them. I also installed 04 roof rails since I had the liner out.
Old Mar 23, 2015 | 12:07 AM
  #55
jimvw57's Avatar
"Ya gots to know your limitations" I have done a few headliners and I was never satisfied with the end results. I don't fit in some of those tight spots. I think I will leave the new liner installation to the pros on this truck. Looks too nice otherwise.
My other projects I didn't really care too much about them and I sprayed some glue up in there only to have it let go a few weeks later. So out came the Straight pins (not a good choice either) I like the idea of the upholstery pins.
I believe I have an aftermarket sunroof that doesn't open. I think to fix it, I need to have the glass open. Not too sure how that is going to work yet...
Old Apr 3, 2015 | 05:28 PM
  #56
Jnj's Avatar
Jnj
Finally got my headliner installed. Paid to have the fabric glued and then I installed back in. Here's two shots. I have to say, I LOVE having suede as my headliner. It really makes the roof seem complete and its so classy
Old Apr 3, 2015 | 06:15 PM
  #57
Like the RC aircraft Jnj ........................... oh, the headliner ain't bad either
Old Apr 4, 2015 | 10:51 AM
  #58
clint70's Avatar
Looks great! Quick question, how complicated was it to remove the headliner? I am going to have to do this sometime soon... do I need any special tools?
Hope mine turns out as nice as yours
Old Apr 4, 2015 | 04:52 PM
  #59
drowssap's Avatar
Very nice
Old Apr 4, 2015 | 05:58 PM
  #60
mln01's Avatar
Guys, guys, guys. For the gazillionth time, just strip off the old fabric and foam and adhesive and paint the headliner. Denatured alcohol strips it clean and the fiberglass shell has a wonderful pebbled finish for the paint. Prime it with kills and then use two coats of a good exterior latex.I painted mine several years ago and it still looks perfect. And it will never, ever sag again.
