saggy rear
Old May 6, 2007 | 05:41 PM
Default RE: saggy rear
Yes, you don't want to buy some ones warn out bags. Here is a link to the best bags made at $180 a piece with a life time warranty.
http://www.arnottindustries.com/
Mike
Old May 7, 2007 | 12:33 AM
johnnybob06's Avatar
Well.. I was going to write a new thread about this, but since I saw this one, I am gunna vent out on this one...
I've taken my truck to the dealership three times about this stupid leaning. My baby leans to the right, and it is visable if you look at either the front or the back!
I've had the right airbag replaced, and then they "re-calibrated" the height sensors, and it is still off... Then the Service Manager has the audacity to tell me that they can't do anything about it and that it will always be an inch different. Well that damn inch makes a difference!
What else can I do because it is a visable lean...
Old May 7, 2007 | 02:33 PM
As I mentioned on your LRO post. go get the dealer to get the zone district manger involved.
Mike
Old May 7, 2007 | 10:47 PM
Camdisco24's Avatar
It sounds like you dealer has given up. If there is any way you can find an independent mechanic it would be a better situation. They are much more personable usually. Like I said earlier in this post I had the same problem and my indy mech. fixed it perfectly, and for hundreds less. good luck!
Old May 10, 2007 | 08:14 AM
jwb's Avatar
jwb
I havesomewhat of a similar problem with my 99 disco II. I changed a driver siderear tire2 months ago and eversince then , the rear shocks have been going up and then down at random. sometimes the rear stays level for weeks and other times as soon as I park the car I hear the bags deflate. Does that mean the automatic leveling device needs to be recalibrated ?
Old May 10, 2007 | 08:22 AM
First you should always change both bads at the same time especially if you are over 70,000 miles. Di you install a new or used bag and why did you replace it in the first place? As for your current issue, crawl under the truck and see if the air is coming from the bag or the pump area.
Mike
Old May 10, 2007 | 11:23 AM
jwb's Avatar
jwb
I don't mean to steal the thread from Camdisco but I didn't change my bag, I jacked up the rear up from one side to change a tire.Eversince then, the height sensors have beenout of whack. Sometimes the car remains the proper height for weeks other times I can't get the shocks to raise up from the top of the wheel.
Old May 10, 2007 | 05:49 PM
Probably need to get the SLS scanned for codes, see what is out of wack.
Mike
bcolins
Jun 22, 2013 08:55 PM
bmw zhp
Apr 13, 2010 08:15 AM
humroot
Mar 30, 2009 11:45 AM
00discosd7
Dec 27, 2007 07:08 PM
01 Discovery
Dec 1, 2006 12:07 AM
