SAI plugs on heads
Old Apr 23, 2018 | 05:00 PM
zuke's Avatar
Default SAI plugs on heads
I'm gonna delete my sai .what do I need to order to plug the holes in the heads?
Old Apr 23, 2018 | 05:15 PM
LR03NJ's Avatar
If I were to do that, I'll remove the tubes, cut it, crimp the ends and bend it and hammer it flat and return the cut portion back. Cheers
Old Apr 23, 2018 | 06:15 PM
Saturnine's Avatar
You'll get a CEL if you do that btw, unless you can find an ECU from a truck that didn't have SAI originally.
Old Apr 23, 2018 | 07:24 PM
zuke's Avatar
Yep. I am currently hunting down a set with ecu bcu and gauges. I have the motor coming out and thought this would be the time. That sai system is a pet peeves of mine. I want to build this truck to be just what I want
Old Apr 23, 2018 | 09:33 PM
No Doubt's Avatar
Someone welded the 4 SAI bolts closed on my Disco 2. Surely they removed the bolts and welded them not on the truck, then screwed them back in.
They also removed the metal+rubber SAI pipes.
They left the SAI pump, though... so I replaced it with an automatic fire extinguisher for my engine bay. I had one on an older vehicle that wasn't getting any use, so I just moved it to the Disco where it might provide some peace of mind.
twin6
Mar 4, 2017 02:26 PM
Love-Hate Rover
Feb 27, 2014 09:21 AM
Mikedag
Nov 25, 2011 12:04 PM
grandkodiak
Jun 15, 2011 07:20 PM
JBEGIN
Jun 27, 2009 12:38 PM
