SAI pricing?
Old Apr 18, 2015 | 11:01 AM
thegoat's Avatar
Default SAI pricing?
Hey guys, just curious if you have any insight on these SAI pumps I have found. Got that check engine light on and want to replace it before I get the ole smog test done. However, I've found two places to purchase, with a wide difference in pricing. First is our friends over at Atlantic British..... their link:
Pump Secondary Air (Genuine Part # WIB000060 ) - Land Rover miscellaneous from Atlantic British
and the other is roverlandparts.com with their link here:
1999-2004 Discovery II Secondary Air Pump
Only thin I see different is the mounting bracket with AB, which I don't need. Over a $300 difference! Wow, curious if there is some unknown reasoning to me for this before I click on the buy it now via roverlandparts.
Thanks!
-b
Old Apr 18, 2015 | 11:07 AM
OverRover's Avatar
One big reason would be AB sells NEW parts, and RL sells USED parts.
Old Apr 18, 2015 | 11:15 AM
thegoat's Avatar
Clicked on their 'guarantee' and see that they are refurbished. You'd think they put that in the description as well... Anyone have any experience with these? Or this company? Stay away? Good to go? thanks again.
Old Apr 18, 2015 | 11:24 AM
OverRover's Avatar
What year is your DII?
Old Apr 18, 2015 | 11:31 AM
thegoat's Avatar
its a 2003
Old Apr 18, 2015 | 11:40 AM
OverRover's Avatar
" I see different is the mounting bracket with AB, which I don't need"
Check the number on the bottom of the pump, possible you need WIB100030 > Land Rover Secondary Air Pump (Genuine Part # WIB100030) | Land Rover And Range Rover Engine Parts
Land Range Rover Discovery Genuine OEM Factory Secondary Air Pump Valve Injection
Old Apr 18, 2015 | 05:24 PM
thegoat's Avatar
Thank you for the information and a more reasonable solution than AB.
-b
gatorm
Aug 11, 2017 04:04 AM
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
SactoBill
Jan 18, 2007 10:07 PM
Wirefree05
Oct 19, 2005 09:39 AM
