SAI system issue....
Guys-
I have a 2000 DII that is throwing codes 1412 & 1415. The SAI fan will whine at a very high pitch when activated at normal cold start-up.
Here's what I have done already:
-Disconnected and Removed the SAI fan
-Inspected the foam filter - it is in near perfect condition !!
-I hot wired the SAI to see if it would still make the high pitched noise. It does not, it's very quiet. Also blows air very effectively with no issue.
What does this tell you ?? Is the high pitched sound the result of the valves not opening, Meaning this is a Solenoid issue ??
Thanks in advance !!
Todd
Todd
