Sanity Check - Engine Swap
Old Feb 1, 2011 | 03:35 PM
JAC's Avatar
JAC
Default Sanity Check - Engine Swap
A couple of months back I had the engine in my 04 Disco (w/ SAI) rebuilt. Over the past couple weeks I've noticed that I am leaking coolant and my mechanic has looked it over a couple times and unable to locate the problem. He thinks that there may be a small crack in one of the cylinders. He has offered to swap out that engine with a re-built engine from a 2002 Range Rover 4.6 for no cost. I'm not sure if I should push him on an alternative solution b/c I have a one year warranty or go with the switch.
From my initial research, they appear to be the same engine--is that correct? Any other questions that I should ask before allowing him to move forward.
Old Feb 1, 2011 | 03:57 PM
Bundu's Avatar
Banned
They are the same engine.
themdg
Jan 25, 2015 01:52 AM
MrWesson
Mar 15, 2014 01:15 AM
Bob Loblaw
Apr 8, 2013 11:25 AM
BrokeRover
Feb 22, 2012 06:13 AM
JAC
Nov 11, 2010 03:55 PM
