Saudi/Gulf bumper or trim stock bumper
Old Mar 31, 2012 | 07:27 AM
wyrdvans's Avatar
Originally Posted by Frank4
@wyrdvans: that looks pretty good what did you use to do the cutting?
I made a rough cut with an angle grinder to cut away most of the area.
Then I used a 543 dremel bit to clean it up. Dremel 543
Old Mar 31, 2012 | 09:51 AM
slanginsanjuan's Avatar
nice tip on that dremel saw. from experience if you use the normal wheel it will glob up with plastic and refill on the cut....i guess that doesn't do that as it cuts and finishes.
imo, you would have to secure it from the inside with a flat thin piece of something as trying to just get the expoxy (J&B) in the crack will fail sooner or later.
Old Mar 31, 2012 | 11:24 AM
ralphobell's Avatar
Here are some pretty good instructions for repairing cracked plastic bumpers.
How To Fix A Cracked Plastic Bumper Cover With Flexible Epoxy Glue
Old Mar 31, 2012 | 11:27 AM
ebg18t's Avatar
I have a excellent condition 04 bumper in FL if someone needs it.I took it off to install my winch bumper.
Old Mar 31, 2012 | 04:30 PM
mbonthenet's Avatar
Thanks...great info & tutorial!
CRB357
May 9, 2015 08:00 PM
yloDiscoII
May 6, 2014 09:46 AM
taylorm334
Feb 17, 2014 03:50 PM
Disco Mike
Apr 25, 2012 06:49 PM
N.Franklin
Appearance & Camping Set Ups
Feb 20, 2008 03:53 PM
