scan tool and code reader (Atlantic British) question
Old Feb 4, 2012 | 09:14 PM
kpl1228's Avatar
Default scan tool and code reader (Atlantic British) question
Any of you guys got one of these? What will it do and what won't it do (I need something to clear service engine codes and 3 Amigos). click link below
Scan Tool & Code Reader - Basic Plus - OBD2 Diagnostic Tool By Innova With Live Data & On-Screen Code Definition (D3040 Same Fit As Genuine Part # 3040) - Land Rover diagnostics from Atlantic British
Old Feb 4, 2012 | 09:23 PM
Justa a code scanner. Won't do the Amigos. See http://rswsolutions.com/index.php?op...d=56&Itemid=55 for one device.
Also consider the Ultra Gauge as a code reader scanner (also won't do Amigos, but makes a great dash gauge for most everything else). UltraGauge Automotive Information Center and OBDII Scan Tool
Old Feb 4, 2012 | 09:59 PM
kpl1228's Avatar
the rswsolutions unit won't reset service engine light though?
Old Feb 4, 2012 | 10:02 PM
I don't have a D2, so have not had that demon. May have to use a regular reader for that, but you should be able to do a search on here for that Amigo device. Moving up the hill is the Hawkeye, which does both and more, in the $500 - $600 range. See Hawkeye Diagnostic Tool for Land Rovers - D.A.P.
Old Feb 4, 2012 | 10:11 PM
You are in a ton of luck because you own a DII, you my lucky friend need two, thats right, count them, TWO scanners, one for the engine codes and yet another for the ABS codes.
So you can spend the $85 plus shipping on the one that AB sells and then another $200 on the ABS Amigo.
Or you can spend $80 delivered for the Ultra-Gauge and another $200 on the ABS Amigo.
I have the Ultra-Gauge and I LOVE IT!!
Or you can go all out and buy the Hawkeye which will do everything.
Old Feb 5, 2012 | 06:51 AM
kpl1228's Avatar
good enough for me----ultra gauge sounds terrific. Thanks all
Old Dec 26, 2016 | 11:55 AM
Charlie_V's Avatar
I have the iCarsoft i930 (about 100 dollars) which is a full scanner and resets all systems (even srs and abs) and is land rover specific. But I found a newer one that looks even better... "iCarsoft LR II for LandRover" on Amazon. $165.
Old Dec 26, 2016 | 12:46 PM
MetalMarine's Avatar
i also use the iCarsoft i930.
Does the iCarsoft LR II turn off the sls or still need a hawkeye for that?
the iCarsoft LR II looks pretty nice though.
Old Dec 26, 2016 | 01:04 PM
Damn Charlie a 4 year old Zombie thread
Old Dec 26, 2016 | 02:07 PM
Charlie_V's Avatar
Oh shoot. My bad!
