ScanGauge question
Plus, I'm installing an oil pressure gauge that will make the almost-useless factory temp gauge impossible to read. Basically, the ScanGauge will be the primary means by which the coolant temperature is monitored. An audible alert would be nice, but isn't a dealbreaker. I know some of the ScanGauge competitors' do, but the ScanGauge seems to be the highest quality and the unit most likely to have a "factory" look.
The ScanGuage is cool. And the ablity to compare the F* water temperature to the air intake temp is cool. Plus the display matches the green on the instrument cluster. It looks like a great edition and is well worth the $175 to have an on-board OBDII reader and code re-setter on your steering column.
agree with all of that. especially when you have a code that no one can ever solve... like moi.
audible, clear, competitors, factory, forum, ii, land, landroverforums, lr3, programing, rover, scangauge, scanguage
