Scrapyard run!
Old Aug 12, 2020 | 12:34 PM
TyTyBinks's Avatar
Default Scrapyard run!
I am going to the scrapyard today and I was looking to see what parts I should get? Any parts prone to fail?
Thanks,
Tyler
2001 D2 with ACE
Old Aug 12, 2020 | 12:36 PM
whowa004's Avatar
drip rails, cup holders w/ inserts are some easier ones. Really when I go I'm on the look out for any part in better condition than what's on my truck. Could be door cards, seats, light housings. Might get lucky and find a roof rack or bumpers on the vehicle (rare but it does happen).
Old Aug 12, 2020 | 12:41 PM
frostythor's Avatar
OK here goes,engine, gearbox, transfer box, steering box, prop shafts, axle front and rear, sunroof front and rear radiator, brakes, ACE system, cooling system,door glass, AC, headliner, headlights, side lights, doors, wings .......
just buy the whole car and get all the spares you are going to need , when you completed the refurb on yours sell the rest on to another deserving Land Rover owner
Old Aug 12, 2020 | 12:49 PM
greisinb's Avatar
Just did this myself! I have a running list of maintenance items on my truck, including things that work, but maybe could be replaced. Take a few moments and comb through your truck and see what you would replace if you could, then take that list to the wrecking yard. I also find it helpful to research how to remove those items first, so you can be prepared with the correct tools.
Old Aug 12, 2020 | 12:50 PM
TyTyBinks's Avatar
Thank you so much I will see if they have that
also who wants to buy a newly refurbished Land Rover from me!!!
Old Aug 12, 2020 | 12:53 PM
Best4x4's Avatar
I find em with aftermarket lifts/shocks quite often. I have scored a set of RTE rock rails for 36.00, but I missed a 65.00 arb front bumper and that sucked lol.
Interior trim/exterior trim, look for an aftermarket front drive shaft, head lights, dash bezel surround, center dash bezel, 04 CDL/03-04 SLABS, and anything you need/can use = grab. Junk yard D1/D2's are slowing down.
Old Aug 12, 2020 | 12:55 PM
DodyDisco's Avatar
Xyz switch/rebuild and keep as spare , Abs cpu if newer version. ECU, Fuse panel box, Visor clips. Horn buttons ,Cup holders,Cruise control switches on steering wheel, Air filter housing if yours has cracked off clips. CD changer cartridge if u need it. List goes on for hours, Yep just buy the whole thing for spares.
Old Aug 12, 2020 | 01:56 PM
JUKE179r's Avatar
Drivers side mat... hell... all mats.
Whole fuse box assembly complete with extra fuses, fuse links and relays.
Both horn buttons.
Old Aug 12, 2020 | 02:25 PM
Richard Gallant's Avatar
ABS pump if you can get it cheap, mine cost 50 bucks which is cheap for spare
sdhow
Sep 5, 2014 11:30 PM
treadhead
Aug 25, 2014 06:52 PM
galahad
Jul 16, 2014 06:06 AM
lholho
LR2
Oct 5, 2008 02:10 PM
Dansker med Rover
Mar 30, 2008 10:22 AM
