SD rack without clamps.
Old Jan 22, 2016 | 08:44 PM
cappedup's Avatar
Default SD rack without clamps.
I've got the opportunity to buy an SD rack, but it doesn't have the lower clamp bits. Owner took em off and lost them.
Is this a bit I can fabricate easily enough? I can get it cheap, but is it worth it?
Old Jan 22, 2016 | 11:03 PM
Alex_M's Avatar
Shouldn't be too hard to fabricate if you have the ability. Just curious, how good of a deal is cheap? There are a couple other option like these which may fit with little to no modification (not sure) or if you search eBay for "van gutter mounts" you should find a bunch of cheaper options that you should be able to modify to work.
Old Jan 22, 2016 | 11:12 PM
coors's Avatar
If you have the ability anything is possible. The real question is do you have the time? How much is your time worth? Now, ask yourself how cheap is cheap?
...me thinking out loud.
Old Jan 22, 2016 | 11:15 PM
coors's Avatar
I'd be willing to send you pics / measurements of my SD gutter clamps if you choose to fabricate your own. Are you familiar with Google sketchup? I can send you a skb file. PM me.
Old Jan 23, 2016 | 11:33 AM
cappedup's Avatar
Cheap is a couple of hundred bucks.
I love Google Sketch up.
I already have a Hannibal rack, which I love, but I'm thinking i could sell that, get the SD rack up and running and use that instead. Depends how things work out.
I'm happy welding up some brackets.
Will send PM.
Old Feb 2, 2016 | 08:28 PM
cappedup's Avatar
So, the dude selling the rack is potentially selling vehicle tomorrow, so it might go.
If it doesn't. Is this the only kit I need for an SD rack without gutter clamps? Description fits, but the photo isn't describing what needs to happen, to me.
Cos $75 plus the rack for a steal = tidy profit.
Old Feb 2, 2016 | 09:05 PM
ZGPhoto's Avatar
Is it a d1 or d2 rack? high or low?
Old Feb 2, 2016 | 09:51 PM
LR03NJ's Avatar
You can use uneven angle bar. 8 pieces of them. Just add washers or spacers between the gap of the clamp. Cant be too thick or it will scrape your door. SD rack has a protruding tube between the mounting holes, thats where you add spacers. You can eliminate the countersinked 3rd smaller hole that pulls the bracket up the clamp. Then you can angle the edges to match the original. Unlike Roverracks which is basically a straight angle and rectangular. Let me know if you need pictures of the piece.
Old Feb 3, 2016 | 09:47 AM
BackInA88's Avatar
This guys is selling some brackets.
https://discoweb.org/forums/showthread.php?t=93192
Old Feb 6, 2016 | 02:07 AM
mx468's Avatar
Hey cappedup if you want to sell the Hannibal I might want to buy it back keep me in the loop. Dan
