SE/SE7 Question
Old Jun 20, 2016 | 12:19 PM
d.a.r.y.l's Avatar
Default SE/SE7 Question
Will the rear jump seats from the SE7 fit the SE? If so is it a lot of work just to gain two more seats? Thanks for the help. D*
Old Jun 20, 2016 | 12:37 PM
Paul Grant's Avatar
The hardest thing about installing rear jump seats is making sure you get everythinh you need. The only point where you'll really have to improvise is at the floor seat belt mounts. You'll have to drill a hole in the floor and secure the belts with nuts and bolts. I don't remember ever seeing the mounts with captive nuts on the underside of the floor on vehicles that were not equipped with jump seats from the factory.
You will have to remove everything from the cargo area to do the job correctly. Not the hardest job you'll do on your Rover but it is tedious and there are a lot of parts to install. You should be able to do the job in one long day.
Old Jun 20, 2016 | 12:42 PM
d.a.r.y.l's Avatar
Thanks. Since I have an SE7 I should have all that I need. I had forgotten about needing to anchor the seatbelts. D*
Old Jun 20, 2016 | 01:13 PM
Paul Grant's Avatar
If you're going to do it with both trucks side by side, it's going to be very easy. I've sold a number of these complete conversion kits to customers who were thrilled to have the extra capacity.
Oh, I should have asked, your SE7 doesn't have rear A/C does it? If so, that may pose a bit of an issue using the left side jump seat in an SE.
Old Jun 20, 2016 | 01:21 PM
d.a.r.y.l's Avatar
The SE7 has been sitting for about three years with bad head gaskets and a few other issues. I just don't remember if it has rear air,I guess I better look. The SE needs a transmission so I'm considering using the SE7 as a donor since it has a good tranny. D*
Old Jun 20, 2016 | 09:39 PM
abran's Avatar
I just did 2 installs in the last month. The captive nuts for the rear seatbelt mounts were there. I think there was tape over the holes.
Old Jun 20, 2016 | 11:42 PM
acg's Avatar
acg
The factory SE7 comes with a heavier-duty rear springs. Hope the attached will be useful.
Old Jun 21, 2016 | 06:55 AM
d.a.r.y.l's Avatar
ACG,thanks for the seating instructions. After going through it I might rethink my project. D*
Old Jun 21, 2016 | 12:25 PM
acg's Avatar
acg
I converted my SE to SE7. It is mostly gruntwork and nothing complex to install.
Old Jun 21, 2016 | 12:32 PM
d.a.r.y.l's Avatar
I'll need to see how important the wife thinks it is. I'm not afraid of grunt work mostly because I'm at that age that I grunt each time I bend over. D*
