SE7 seat folding issue
Old Sep 29, 2012 | 02:57 PM
Indiana Jones's Avatar
Default SE7 seat folding issue
hey guys, my SE7 is an SE6 for the moment... once locked in the down position i cant seem to get my right rear seat to unfold and lock upright. it just stays locked down. stupid me tried to force it and broke the handle. is there a common issue that keeps the seat from unfolding? id like to get it fixed. if i cant fix it ill sell the seat and get a cargo compartment or something. thanks gents
chris
edit: vehicle is an 01 Discovery 2 SE7 (SE6 )
Old Sep 29, 2012 | 03:51 PM
humroot's Avatar
chris
If you look under the seat, there is a cable that runs from the latch to the handle on the back. Mine is broken so I either grab the cable from under the seat and pull it, or use a screwdriver to release the latch and tilt the seat up for better access. Same goes for the tilt latch.
You can take that seat out with four bolts and then you can work on it in the garage. As long as i know i can get the seat up and down, I don't worry about it...too many other things that need attention!
Old Sep 29, 2012 | 08:04 PM
jafir's Avatar
My 99 does this when the seat isn't fully locked down. I'll bet if you tug up on it, it will pop up. Just slam it down a bit harder and i'll bet the seat back will unfold.
See this too: http://www.landroverclubvi.com/uploa...provements.pdf
RocketScott
Feb 14, 2010 01:44 PM
Robmcin
Apr 9, 2009 07:55 PM
Young
Nov 21, 2008 07:43 PM
saratogarr
Jul 9, 2008 06:07 PM
cpalacay
Dec 4, 2006 09:15 PM
