Sea Foam Before Oil Change?
Old Apr 21, 2009 | 02:55 PM
nashville rookie's Avatar
Default Sea Foam Before Oil Change?
Someone recommended adding Sea Foam to my oil just prior to having it changed. Can anyone support this?
2004 Disco II
45,000 Miles
Old Apr 21, 2009 | 03:05 PM
okdiscoguy's Avatar
It will knock out carbon deposits from your rings. It may also seep around your rings. Seafoam and then change the oil.
Old Apr 21, 2009 | 03:19 PM
If you want to clean out your engine, consider using 1 quart of any engine flush 5 or 10 minutes before an oil change, you will get much better results. Then buy 2 cans of Seafoam, one for the gas tank one for an induction cleaning.
Old Apr 21, 2009 | 03:26 PM
Does the RAVE CD cover induction cleaning?
Old Apr 21, 2009 | 03:35 PM
okdiscoguy's Avatar
Nope, just unhook a vacuum line and suck the can slowly into the intake. Shut it off for 10 to 15 minutes. Fire it up and drive it like you stole it.
I thought you were asking about an induction cleaning before oil change. Don't use seafoam in the oil, use it in the gas tank and induction. If you want to flush your engine, buy an engine flush or switch to synthetics and let them do their job.
Old Apr 21, 2009 | 04:52 PM
As mentioned, no it doesn't cover it. PM me with your tele number and I can walk you thru this.
bigugly82
Mar 14, 2018 05:09 PM
DeepBlueWater
Oct 16, 2007 10:23 AM
Camdisco24
Aug 7, 2007 04:44 PM
mowthat
Feb 14, 2007 10:03 PM
mikemeyer0
Jun 16, 2005 04:00 PM
