Seafoam procedure: Seeking detailed specifics
Old Jul 4, 2009 | 05:37 PM
Torancis_LR's Avatar
Default Seafoam procedure: Seeking detailed specifics
Okay, I have read many threads about this Seafoam process and am looking for more information.
Upon looking in other pictures where the nipple location is, mine seems to have a zip tie around it (see picture). As you can see, I do not have that red ring but I hope you can see. It also seems to have a larger rubber plug. I am beginning to fear that it may fall off after I plug it back. I might need extra zip ties then.
So is it safe to have the engine running during the removal of the nipple plug into the Seafoam hose. Or turn the engine off, connect the hose then turn engine back on?
Also, I understand to clean the throttle bottle as well with carb cleaner. I have included the pictures and I am assuming you loosen the bolt right below the yellow warning decal and you'll see the throttle?
Next, when I spray the carb cleaner, do I let it sit dry or wipe it down clean. Also, do I pull one of the cables on the left side to access the butterfly?
I will take pictures of this process as reference to the community. Can't wait to smoke the street out.
Cheers.
Old Jul 4, 2009 | 06:31 PM
Loosen the worm clamp on the throttle body air intake tubing and move the tubing out of the way, spray all around, open the butterfly by moving the throttle, that is the thing with all the cables.
Spray everything that you can see, dont scrub, dont wipe, dont let it dry, spray, put it back together and then start the truck.
She will be hard to start because she will be flooded, once the exhaust is clear once again you can shut her back off.
Old Jul 4, 2009 | 06:34 PM
If you want some step by step information, send me your tele number and I'll call you.
jycsalas
Sep 13, 2019 09:44 AM
LAWYER2
Dec 20, 2012 05:58 PM
soiltron
Oct 27, 2009 09:40 AM
tom_meeks@yahoo.com
May 23, 2008 09:48 AM
Lebowski87
Jul 13, 2006 08:40 PM
