Sealing the center console plate
Hey everyone,
A couple weeks ago I put in a CDL linkage. I have two questions. When I remounted the plate, I actually put the plate on top and screwed it down into the chassis instead of the plate being under. I didn't really see any reason this would be bad, but any input?
Also, this might be because of the way I reattached the plate, but it is quite a bit nosier now. I used RTV sealant around the plate. My question is, is there anything else that can be done to dampen the noise a little bit? I know that on top of the plate there is a rubber gasket thingy that seems like it was meant to dampen sound and be more water tight.
Any input would be greatly appreciated.
Thanks
Thanks
I'm not quite sure what you are getting at, but from your description it sounds like you attached to the body, a part that should be attached to the transfer case. If this is true it will probably be transmitting more vibration into the boy of the truck and that's why it is louder. Pictures would help explain a little better.
Hey everyone,
Thanks
Thanks
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
I do not see any problems w/ the way you sealed it up. I also noticed a bit more road noise after re-sealing every thing all up. I did it the same way as you w/ the screws instead a rivets. I went a step further than you, along with the factory "rubber gasket thingy", I purchased a rubber boot from an auto parts store, the ones used for a manual trans floor shifters and installed it under the plate in an attempt to create a better seal. This might be ghetto, but I also packed insulation underneath the leather gaiter boot and it seemed to work quite well. ![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Also if your careful you could apply a layer of expanda foam around the edge of the plate and the for the cut out for the shift lever to move side to side coors had a great idea. But you could take a little piece of the foam insulation and pull the plate up pinch it between the plate and the shifter leaving a slit to still allow the movement to shift.
badfysh
76
05-27-2016 11:16 AM
Rover_Hokie
09-20-2012 07:17 PM
