Secondary Air
Secondary Air
Just had the 60K service done on my 03 Disco and have been reading that if you have secondary air..i.e..rear air, you should let a mechanic do this.. Is this because it is difficult to change the spark plug wires or is there something that I should have made sure this mechainc did when he did the service.
RE: Secondary Air
Secondary air makes it very tricky to change the plug wires.
DiscoMike on here is a retired service writer, follow the link to seee what he suggests for a 60K service or to anyone with a new to them Disco...
https://landroverforums.com/m_27641/tm.htm
RE: Secondary Air
Dont get lost here, but secondary air and rear air are two totally different things. the cars equipped with secondary air ,LEV Equipped engines (low emissions vehicle)are just a little more difficult to work on, Rear Air refers to rear air conditioning , and a 60 k service really dosent require any different procedure except to inspect the vaccum connections and hoses.that are visual by simply glancing under the hood, no big deal.
