Secondary air injection solenoid
Old Dec 9, 2012 | 02:01 PM
iddisco's Avatar
Default Secondary air injection solenoid
I have the engine code p0414. There is exhaust coming out my sai pump and its quite loud. I don't think the pump is functioning. The solenoid has been replaced and I have checked the voltage And the solenoid is always engaged or grounded. In my mind that means either bad wiring to solenoid from ecu or bad ecu? Could the CPU leave the valve open if its getting a bad reading from say the maf or temp sensor? I will be replacing the pump but need the valve to work properly first. For context it's a 2001 disco with 175,000 miles. Any suggestions?
Old Sep 13, 2013 | 08:14 PM
dinava's Avatar
7th Gear
Default I have the same problem...
Did you ever find a solution to your problem? Was it wiring or ecu? I think mine is wiring but I'm not sure where those wires go specifically and I would like some direction before I start cutting ecu wiring harnesses?
Old Sep 13, 2013 | 09:04 PM
The RAVE electrical manual may be of some help with color coded diagrams and pictures of connector locations, etc.
redwhitekat
Jan 12, 2014 05:06 PM
colin2496
Oct 17, 2011 09:58 AM
aublec22
Mar 20, 2011 01:28 PM
dg17319
May 27, 2010 06:42 AM
John Doud
Mar 25, 2010 08:22 PM
