Secondary air pump flexible hose NOT FLEXIBLE
Old Dec 30, 2014 | 10:17 PM
cybercop's Avatar
Default Secondary air pump flexible hose NOT FLEXIBLE
While taking off the Secondary Air pump, which was full of water for some unknown reason,
I broke the "Flexible" Secondary hose!
Is it ok to use some standard black heater hose from a autopart store? The "flexible" hose that broke is corrugated and not sure if it is that way for any reason. All it should have to do is carry air flow!
Old Dec 31, 2014 | 02:00 PM
DoubleK's Avatar
Mine broke and I used heater hose with no problems that I am aware. But, I'll take look when I can to see if it is collapsing.
Old Dec 31, 2014 | 02:01 PM
cybercop's Avatar
Thanks, that would be great!
Old Dec 31, 2014 | 02:17 PM
ZGPhoto's Avatar
They break ALL-THE-TIME!
Old Jan 2, 2015 | 12:12 AM
cybercop's Avatar
Heat hose worked, but it puts alot of torque on the simple snap on connector to the air pump. I'm scared it's going to just pop off.
Does anyone know what the piping the OEM cross pipe is made out of. Might try to find a source and buy a roll of it.
Old Jan 2, 2015 | 01:05 PM
jfall's Avatar
I used heater hose.
Take a look in the video here
Old Jan 2, 2015 | 03:32 PM
DoubleK's Avatar
Glad you got the heater hose on, I still haven't had time to see if mine collapses.
I think I popped the elbow out while trying to get heater hose on and it just popped back in, but it's been a while and memory is fuzzy.
Old Jan 2, 2015 | 04:01 PM
cybercop's Avatar
JFal, That is a major OCD Cleaned engine. Come do mine.
Where did you get the Heat shield stuff that you put around the pipes and plug wires from!
USAroverman
Mar 17, 2015 01:56 AM
PackAttack12
Jun 1, 2012 09:05 AM
outdoor7or24
Apr 1, 2012 09:01 PM
jdelp
May 30, 2007 03:49 PM
akartis
Sep 25, 2006 01:31 PM
