Seized viscous fan nut
Old Sep 21, 2021 | 03:34 PM
Harvlr's Avatar
Default Seized viscous fan nut
Does anyone have wisdom on getting the nut loosened? I have the pulley jammed with a pry bar and I’m tapping quite hard on my 36mm wrench. I’ve been soaking it in penetrating oil for a few hours. (P38 GEMS engine)
Difficult to get a good shot.
Old Sep 21, 2021 | 03:38 PM
whowa004's Avatar
See if you can rent an air tool designed just for this. Had to borrow a friends one day and it made quick work of the stubborn nut.
Old Sep 21, 2021 | 03:45 PM
Harvlr's Avatar
Oh wow. Thanks for the reply. That’s got to be a pretty specialized tool to fit in there.
Old Sep 21, 2021 | 03:53 PM
whowa004's Avatar
It's a neat attachment that basically uses an air hammer type deal to break it free. That hi-frequency impact action does wonders.
Old Sep 21, 2021 | 04:03 PM
Best4x4's Avatar
Standing from the front it goes Counter Clockwise to remove. I've used a beefy 36mm open end and usually hit straight down with a sledge and it will break loose. Or the Snap On tool style where you hold the Waterpump Pulley bolts with one tool, and loosen with the 36MM wrench.
Old Sep 21, 2021 | 04:21 PM
Harvlr's Avatar
Thanks. I’ll give those ideas a try
Old Sep 21, 2021 | 05:16 PM
Harvlr's Avatar
Got it. Clearly the “special wrench “ has way too much flex. Need a much beefier 36mm wrench, which I’ll have to buy for next time. I used a fairly beefy 12” crescent and a heavy hammer.
Old Sep 21, 2021 | 06:04 PM
Extinct's Avatar
Neverseize on the threads going back, don't even tighten it as the fan load keeps it tight. Freaking ******** that tighten those.
Old Sep 21, 2021 | 06:22 PM
Harvlr's Avatar
Good call. I use ant-seize on almost everything
Old Sep 22, 2021 | 08:04 AM
H Hill's Avatar
A question of preference:
Do you use the silver anti-seize or the copper based? A good friend, a LR mechanic from Manchester England, always swore by the copper based product.
Just curious.
