Sensor on the Transfer Case?
Old Jun 1, 2014 | 08:58 PM
bcmouser's Avatar
7th Gear
Default Sensor on the Transfer Case?
2001 Disco II SD
I recently replaced the transmission due to drive shaft negligence (make sure to service those, folks). Once everything was back together, I took a couple days to check over everything to make sure it was back together right and realized on the drivers side of the transfer case, there is a sensor (?) that has one of the teeth broken off and the wire that connects to that tooth is melted down a few inches. I'm not sure if I did this during disassembly or if it was done beforehand.
I've looked at my RAVE and searched here, but can't really find the answer I need. Anyone know what this part is? Clearly I need to replace the sensor. Do I also need to replace the wire harness or can I electrical tape it up?
Also, the photo is upside-down, for some reason. Sorry about the orientation problem.
Thanks again for the help!
Old Jun 1, 2014 | 09:07 PM
ralphobell's Avatar
That is the Transfer Case Temp Sensor.
LR Part# PRC7984
Old Jun 2, 2014 | 10:33 AM
bcmouser's Avatar
7th Gear
LR Part# PRC7984
that's what I kind of thought it was, but couldn't find any confirmation! Just ordered the transfer case wire harness and the sensor.
Thanks for the response!
Ghaniba
Apr 28, 2020 10:19 PM
KlamathMatt
Apr 17, 2020 05:27 AM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
