Series II A/C Woes.
Old Aug 25, 2009 | 05:01 PM
xb70valkarye's Avatar
Unhappy Series II A/C Woes.
Got a 1999 Series II with a moody air conditioning system. No matter how low you set the temperature the air conditioning does not want to come on. drive it around that way for a while (sometimes 5 min and sometimes 30 min or more) and suddenly the air conditioner will kick on and blow ice cold! Turn the Rover off and back on and the story repeats itself.
Upon further inspection I noticed that the compressor is not kicking on. The refrigerant level is where it is supposed to be and there are no leaks. So does anyone have any idea what would keep the compressor from kicking on? Is there a hi/lo refrigerant sensor?
Any help would be appreciated.
Fred
Old Aug 25, 2009 | 05:17 PM
lipadj46's Avatar
Maybe one of your temp sensors are faulty?
Attached Thumbnails Series II A/C Woes.-picture-7.jpg
Old Aug 25, 2009 | 06:54 PM
I don't think it is the temp sensor because the system works perfectly for heat and the blower changes speed like it is supposed to. And with the temp on the "LO" position should the temp sensor not be taken out of the loop?
Fred
Old Aug 25, 2009 | 08:22 PM
lipadj46's Avatar
True. The only other easy thing is the freon level and you said that was fine. Maybe the condenser clutch.
Old Aug 25, 2009 | 10:31 PM
Darover's Avatar
Play with the plug-in under the hood at the compressor. wires sometime get loose within the plug-in itself.
Old Aug 26, 2009 | 10:20 AM
How do you know the freon level is OK?
If you jump the compresor, will it start and is it stone cold?
Old Aug 27, 2009 | 01:22 AM
My friend is an Auto tech. We took it to his shop and he had a machine that pulled out checked and refilled and the amount was as required by sticker under hood. It does not have rear A/C so its the smaller amount.
How do you jump the compressor?
Fred
Old Aug 27, 2009 | 11:34 AM
With a wire from the positive side of the battery to the hot wire on the compressor, if the compressor fire right up then I would look at the pressure switch as a possible issue.
Old Aug 29, 2009 | 03:11 AM
Will check and get back. Thank you
inline6
Aug 27, 2007 04:47 PM
Rub
Feb 23, 2007 01:11 PM
AlexERAsDisco
Dec 16, 2006 03:18 PM
McDougal
May 5, 2006 06:04 PM
95roverV8i
Mar 26, 2006 03:29 PM
