Serp Belt tensioner replacement alternative!
Old May 5, 2010 | 10:19 AM
audiS4S6's Avatar
Default Serp Belt tensioner replacement alternative!
I noticed the bearing on my serpentine belt tensioner was a little rough when I removed it. I went searching for a new roller but found I could not get the roller separately from the entire tensioner.
I looked at the roller and noticed the bearing was just secured with cir-clip. I got the number off the bearing and found it at McMaster-Carr for $12.
P/N: 2349K422 if any one is interested. I am ordering mine today.
Old May 5, 2010 | 10:27 AM
greg409's Avatar
nice to know, I"ve replaced the pulley, tho' don't remember from where
http://www.autopartsdeal.com/catalog...t+Idler+Pulley
It wasn't from these guys, but they're out there for comparable money.
luck,greg
Old May 5, 2010 | 10:55 AM
You can buy just the bearing but unless you have a press, you are better off buying a pulley say from Atlantic British.
Old May 5, 2010 | 08:07 PM
audiS4S6's Avatar
The bearing just tapped out with hammer when I took the clip off. I'll put a little Loc-tite around it when I install it. Should work just fine.
I guess I'm glad I didn't find the pulley separately!
Old May 5, 2010 | 08:08 PM
audiS4S6's Avatar
ah crap! $22? Yeah, just buy the pulley. I'll be over in the corner keeping my pie-hole shut...
Old May 5, 2010 | 08:20 PM
I bought my pulley like 2 years ago from Autozone for $20?
Also bought my oil pressure sensor from them, $14.
Serp belt, plugs, air filter...you get the idea.
You dont always have to order online.
That is good to know about the bearing though, incase someone cant get the pulley anywhere.
jrm123180
May 5, 2010 04:00 PM
Spike555
Mar 5, 2008 12:04 AM
DeepBlueWater
Nov 11, 2007 01:21 PM
raid13
May 19, 2007 01:00 PM
AustinJeff
Mar 15, 2007 07:53 PM
