Serpentine belt change...need HELP
Old Feb 28, 2008 | 12:36 AM
Robeye's Avatar
6th Gear
Default Serpentine belt change...need HELP
Blew the belt today and what a joy. I figured out the route, but how do I tight/losten the new belt? American cars, losten alternator. Disco...not a clue. I am mechanically enclined, but I am lost. It is an "02" Disco I need to fix. I took off the water/heater hose so I will be able to get the new belt looped. What else? Thanks a MILLION in advance.
Old Feb 28, 2008 | 06:24 AM
jkid's Avatar
Default RE: Serpentine belt change...need HELP
Yeah it's not like most vehicles, there is no adjustment, just a spring. The tensioner is below the alternator and above the idler pulley on thepassenger side of the engine. You need to get a wrench on it and turn it clockwise I think. This will rotate the whole pulley mechanism inward so you can slip the belt on.
Old Feb 28, 2008 | 10:31 AM
Robeye's Avatar
6th Gear
Thanks. I figured as much, but could not figure out how the spring or tension is loaded. My rig is 30 miles from my home, so I want to be sure I got it right. Thanks again.
Old Feb 28, 2008 | 11:32 AM
Landzu's Avatar
Look here
http://www.roverparts.com/TechTips/s...routing_D2.cfm
real_tea
Aug 21, 2015 10:14 AM
joshsrover
Apr 2, 2008 11:03 AM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
