Serpentine Belt jumping
Old Aug 24, 2009 | 01:03 AM
guywithadisco's Avatar
Default Serpentine Belt jumping
So a couple weeks ago I changed the serpentine belt. All of a sudden a couple days ago it started making an awful squealing noise. Took it to a friends shop and they said, well water pump is going out. Got a new one and put it in, started it up and there it was. Still squealing. I have now found that when I replaced the serpentine belt it was not put on right, making the squealing. I now have it on right but it will not stay. Soon as you turn it over it jumps over a tooth on the PAS. Is there something wrong with the power steering maybe? Not sure what would cause it to jump like this. Any help would be appreciated. I will post a picture soon as I can. Thanks in advance.
Old Aug 24, 2009 | 06:50 AM
lipadj46's Avatar
Do you have Ace? Did you buy the correct length? The Ace model will be longer. If the correct belt then you may need to replace your tensioner pulley. Does you PAS pump turn?
Old Aug 24, 2009 | 07:37 AM
Have you checked the indicator on the tensioner to make sure the belt is tight enough?
Old Aug 24, 2009 | 11:12 AM
Either you have the wrong belt or your tensioner is bad.
Old Aug 28, 2009 | 10:14 PM
ok figured it out, the power steering was going out, the shaft of the power steering was sticking out almost an quarter of an inch. Got the power steering replaced. But I am wondering where the indicator on the tensioner is, does anybody have a picture of the indicator or maybe be able to explain where its at. Thanks
Old Nov 16, 2009 | 08:18 AM
wisch_st's Avatar
4th Gear
I am having the same issue with my 2001 except I don't have any squealing. I just finished the Head Gasket job, put on a new serpentine belt in the process and after my first quick highway run I heard a ticking noise like I sucked a leaf up near the fan. Stopped and opened the hood and the inside of the belt was shredded.
I have done a visual check and run my hand along the side of the belt closest to the block and there is nothing protruding. Then I noticed that the belt was two grooves in towards the block on the PAS pulley. I used a pry bar on the tensioner and moved the belt back into place on the PAS Pulley and started the engine back up. Everything seems fine, no rubbing noise (only parts of the inside of the belt had shredded), the belt looks like it has good tension, no squealing when turning the wheel or a/c compressor on. Then from under the hood I gave the engine some throttle and watched the belt jump back over on the PAS pulley again.
I have a replacement belt coming in the mail since no one local stocks the belt for ACE, but need to figure out what the problem is first.
Does anyone have information on how to check the tensioner or suggestions on what else to look at?
Old Nov 16, 2009 | 09:04 AM
Sounds to me like your belt tensioner is bad.
I do not know how to test it.
Old Nov 16, 2009 | 09:36 AM
I agree, the belt tensioner is probably weak and not holding enough tension on the belt.
I would also replace both idler pullies which are prone to failing.
Old Nov 18, 2009 | 09:40 PM
wisch_st's Avatar
4th Gear
No dice.
Replaced the tensioner and both idler pulleys and now the new belt doesn't even wait until I rev the engine, it jumps over on the power steering pulley as soon as I start it up.
I have attached a photo of the pulleys and belt. The PAS pump pulley definitely sticks out further than the ACE pulley as you can see from the gap and how the belt is on the idler. The PAS pulley seems to be in line with the crank and water pump pulleys though.
Old Nov 23, 2009 | 12:35 PM
wisch_st's Avatar
4th Gear
If you have the issue I had above, save yourself the embarassment and make sure the Power Steering pulley isn't on backwards
04_Freelander_SE
Freelander
Oct 26, 2008 02:27 AM
joshsrover
Apr 2, 2008 11:03 AM
Benhamtroll
Aug 17, 2006 11:45 AM
Thegix2
Nov 22, 2005 09:25 PM
esaycho
Oct 12, 2005 03:24 PM
