serpentine belt on my disco II, strange situation, need ideas.
So I changed the idler pulley on the passenger side of my '01 DII. I went to put the belt back and it will not fit. I changed it recently and it went together easily after I figured out the tensioner. At first I thought my new pulley may be the wrong size, so I put the old one back on and I still cannot get the belt over the alternator, its like the belt lost an inch or two in the time i spent changing the pulley. I've got the tensioner all the way in and I had a friend helping but still nothing... Am I forgetting a trick or does anybody have any ideas? My daily driver is stranded and I need some sort of guidance, its like I cant get enough slack. Thanks.
You said "put the belt back on." I assume you meant the old one, but just in case you purchased a new one, there IS two different belts. One is shorter than the other. SO if your Disco has the ACE system installed and you perhaps bought the belt for the NON-ACE Discos it would come up a little short. ACE equiped DIscos have one more pulley to turn. Let us know what the issue was when you figure it out.
Ok I feel like a dumbass. I had the belt routed wrong (it was the same belt, wasnt replacing it wich made it weirder). I was convinced it was right 'cause I drew a diagram real quick but I fudged it. Thanks for all the quick responses though, once i saw the official diagram I saw my mistake. Stupid waste of time
IMHO many owners would benefit by making a small copy of the correct diagram, and taping it under the hood with some of that clear shipping tape to cover it all. And a smart fella learns from his mistakes, a brilliant guy learns from the mistakes of others. So by you posting on an open forum, you will help many after you that face the same challenge. Thanks, you really are not very dumb at all.
