Service Engine Light Blinks and I get all this codes for Autozone!!
Ok...went to autozone and got all this codes
P1301 No description Catalyst damaging level of misfire detected on cylinder No.1
P1302 No description Catalyst damaging level of misfire detected on cylinder No.2
P1303 No description Catalyst damaging level of misfire detected on cylinder No.3
P1304 No description Catalyst damaging level of misfire detected on cylinder No.4
P1305 No description Catalyst damaging level of misfire detected on cylinder No.5
P1306 No description Catalyst damaging level of misfire detected on cylinder No.6
P1307 No description Catalyst damaging level of misfire detected on cylinder No.7
P1308 No description Catalyst damaging level of misfire detected on cylinder No.8
The service engine soon light starts blinking after I take off and the truck does not want to exceed 45mph. During the acceleration the service engine light continues to blink and only stops blinking but remains on is at an stop light. I was reading other threads and found out that the coils packs where a last resort and from other threads I am assuming it is a bad MAF! I appreciate all your help!!
RE: Service Engine Light Blinks and I get all this codes for Autozone!!
You can get a MAF for $143 including shipping at : http://www.landautoparts.com/DIS003_2000_parts.html
In case you aren't aware, K&N air filters will foul a MAF. Also (another just in case) open your hood in total darkness with your engine running and check if you see any arcing from your plug wires (could be the culprit).
www.atlanticbritish.com, buy the Magnecors and then return the others for a full refund.
