Service Engine Light Blinks and I get all this codes for Autozone!!
Old Jul 20, 2008 | 07:25 PM
Default RE: Service Engine Light Blinks and I get all this codes for Autozone!!
You bought AutoLite plug wires didnt you? Others on here have had the same problem with...
Old Jul 20, 2008 | 07:26 PM
...their plug wires that they bought from Advanced Auto Parts.
Old Jul 20, 2008 | 07:36 PM
Disco2Guy's Avatar
As a general rule, you should pull over immediately when any of your dash lights are blinking (well except the turn signals). That is how your truck tells you some real damage is being done, not just a warning. I only see 7mm Mag's at AB for $129.95. Call Cerrone's, they carry the 8mm's for $111.00.
Old Jul 20, 2008 | 07:41 PM
2000 Disco 2 SD7's Avatar
You did not say what plugs you installed but if they are Bosch Plus 4 they pull high voltage and need the 8mm wires.
Old Jul 20, 2008 | 07:50 PM
I use AB, but you can by all means use whoever you want. Just to it today.
Old Jul 28, 2008 | 01:38 AM
casanova00's Avatar
Hello guys!!! Soory I had not responded earlier but Hurricane Dolly Visit me Here in Brownsville!! I had replaced the Plugs and Wires on the truck and It was working fine with the wires from Advanced Autoparts. Like I said thats was more than a month ago. The truck started to loose power and the suddenly the service engine soon light started flashing! After I searched the forums I found out that I should stop using the truck, which I did. I also learned that the MAFS could be a potential problem, I ordered the MAFS and when I received it I installed it and the truck performed a whole lot better. I test drove it and the service engine light was on but was not flashing. I went to fill it up with gas then after about five minutes the service engine light starting flashing again. I am running out of options and going crazy. I also read on another forum that it could be the catalytic converters is this true? I appreciate everyone the helps me!!
Old Jul 28, 2008 | 10:03 AM
ORIGINAL: 2000 Disco 2 SD7
It's your MAF most likely - I had the same problem and replacing it was the cure, though you may need plugs and wires.
It is not a MAF!!
Old Jul 28, 2008 | 10:07 AM
Before you go guessing and throwing more parts at it you might want to e-mail me your tele number so I can try and get you back in the right direction. Do not install the ordered MAF, it is most likely not needed.
mikeljacobs@comcast.net
Old Jul 28, 2008 | 04:33 PM
ORIGINAL: Disco Mike
It is not a MAF!!
Sorry if I gave the wrong advice but now I'm curious because he did say the truck ran a lot better with the new MAF installed (though he got a flashing SEL later again).
Old Jul 28, 2008 | 09:14 PM
Its the plug wires!!!! Advance Auto sells crap plug wires, they work fine on a Dodge or a Chevy with a cast iron engine, but on cars with a aluminum engine that disipates LOTS of heat they will not last more than, guess what, a month.
ITS THE PLUG WIRES!!!!
