Service engine soon Disc II
Old Nov 2, 2013 | 01:55 PM
derrickp's Avatar
Default Service engine soon Disc II
Hello all! I got a 2003 Disco II with about 90K and I got a new service engine soon light on with the following codes. p0130 oxygen sensor bank 1 sensor 1 p0171 bank 1 too lean and p1171. I replaced the drivers side upstream oxygen sensor last year so it is almost new. Does anyone know what I may need to replace? Should I replace the other three sensors? Or could the catalytic converter need replaced?
Thanks
Old Nov 2, 2013 | 06:13 PM
rhearon's Avatar
You might want to check your trans fluid level.
Old Nov 2, 2013 | 06:51 PM
ZGPhoto's Avatar
Join date oct. 2012, your first comment is telling a person to check their transmission fluid level....?
Does your cat make any noise?
Old Nov 2, 2013 | 09:47 PM
XCELLER8's Avatar
Thanks
for now anyway, the cats are probably ok......that would be a different set of codes(LOL)
when was the last tune up ? ( plugs and wires, injector cleaner) it could just need a new sensor but many times a good tune up will straighten it out
Old Nov 3, 2013 | 08:52 AM
You should first check for oil or grease in the 02 connection, if dry then replace both front 02's at the same time to make sure both banks have even air to fuel ratios.
Old Nov 4, 2013 | 12:09 PM
xxdoylexx's Avatar
"and p1171" can mean a MAF issue or vacuum leak after the MAF
Old Nov 4, 2013 | 12:59 PM
jfall's Avatar
If you did not put in a BOSCH O2 sensor then your results may vary.
I would do a few things..
Firstly,
assure the exhaust manifold bolts to the heads - are not loose and there is no exhaust leaks there.
Also the Y pipes - no leaks.
I would replace the O2 sensor with a Bosch.
I would also put a scanner on and look at the live data on the O2 sensors.
One may be lazy.
The front O2's oscillate.
The rear O2's don't and put out a constant voltage when
the engine is under load.
Old Nov 4, 2013 | 03:19 PM
The 171 is caused by a failed 02 sensor. First check for oil or grease in the connection, if none then replace both front 02's and get back on the road.
Old Nov 11, 2013 | 06:58 PM
03Discovery4EUX248's Avatar
2003 Land Rover discovery 127,000 miles
I have the same error code. p0130. Bank One, sensor one.
I feel reasonably confident I could change these out. Or as Disco Mike says, "check for oil and grease and other contaminants".
Where are these sensors located? Is there a link that would show a schematic of the parts?
Old Nov 11, 2013 | 09:19 PM
dusty1's Avatar
they be on the exhaust. 1 before cat. 1 after on each side
euronavdiscs
Feb 6, 2016 03:41 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
AMANDAMC
Sep 23, 2007 11:14 AM
hippo2002
Freelander
Dec 19, 2005 01:31 AM
rinmud
Oct 1, 2005 04:32 PM
