Service Engine Soon light on 03 Disco II w/ 108K
Probably O2 sensor, but from what you describe I'd also check your vacuum lines. One may have broken or come loose.
If you are changing it out the 02 sensor yourself then make sure you borrow an 02 sensor tool kit from Autozone. If I remember correctly, the front left you do from underneath and the offset tool is invaluable. It's not a tough job IF the last person used the right anti-seize on the threads
You can get a cheap obdII tool on Amazon, or they have them at all auto parts store. The Scangauge or Ultragauge can be used to monitor engine temps, etc. so hey are a nearly conpulsory part of your cabin considering the factory temp sensor is garbage.
