SES Dash light
Old Oct 13, 2015 | 09:11 AM
DiscoTanB's Avatar
From: Charles Town, WV, originally from Central Valley, California
Default SES Dash light
The SES light is on on my '03 Disco II (128k miles). Did an OBD scan check which showed P1412 and P1415 codes (SAI leak/bad solenoid). I also recently replaced the air filter with a K&N filter which some here think is not so good. My mpg's have dropped over the last couple tankfuls and my question is this:
could either or both of these issues (codes/filter) be the cause of the sh**y mpg or is something else at work? I am in the middle of a major service so any help would be appreciated. Regards, Art
Old Oct 13, 2015 | 02:03 PM
abran's Avatar
Yes, these could effect your MPG.
When I got both those codes I changed out the purge valve with the genuine Hyundai part and it fixed it, twice(2 different vehicles).
Hyundai part number is 28910-22040
Old Oct 13, 2015 | 02:51 PM
DiscoTanB's Avatar
Thank you Abran. I found a disconnected hose (fixed) but at 128K miles I may change out the purge valve anyway.
Old Oct 13, 2015 | 03:30 PM
rtonder's Avatar
LR uses 12 and 15 codes to indicate low air flow for bank one and two, respectively. If you fixed the leak on the main hose you got both of them.
millejdq
Jan 9, 2023 10:46 PM
pjvarc
Aug 5, 2011 04:23 PM
Disco_Fever
Apr 26, 2011 11:59 AM
morfa
Oct 27, 2006 10:43 PM
rdisco2
Sep 21, 2005 01:12 AM
