SES Flashing and Disco Shuddering
Old Jul 13, 2009 | 05:52 PM
bangkuaidiscovery04's Avatar
Originally Posted by lipadj46
http://www.apexperformance.net/cartg...t.asp?scat=306
Buy the 8mm magnecors or the OEM wires but the Magnecors are better and cheaper but still $85. Don't scrimp on this part just get the Magnecors from Apex they will come fast.
Thanks for the link appreciate it. Will order before the end of the week so I can install it along with the front driveshaft rebuilt. Probably should get new spark plugs as well.
Old Jul 15, 2009 | 02:06 PM
How many do I buy? Quantity of 1?
Old Jul 15, 2009 | 03:49 PM
lipadj46's Avatar
Yes 1 set, they will come in a set of 8 cut to the correct sizes.
Old Jul 15, 2009 | 07:59 PM
Originally Posted by bangkuaidiscovery04
I just got back the codes read.
Here they are:
P1174
P0441
P0300
P0301
P0306
P1300
You're right about the front driveshaft rebuilt I'm doing that before the week is over. The codes are all related according to the scanner. You're probably right about changing the wires, the engine keeps on misfiring on 1 and 6. Just got an oil change last week with 5W40-All Temperature. Could that have created a problem also? I'm pretty upset right now because all this came out of nowhere!
How mechanical are you? If you have never rebuilt a double cardone drive shaft, don't start now, find a shop and have 2 new greasable u-joints and a centering ball kit, apx $225 parts and labor.
That 441 is a separate issue with the evap purge flow but it won't cause the flashing lights.
Old Jul 15, 2009 | 09:49 PM
I won't be doing the rebuilt we have a family mechanic who does everything for us and does a great job. What do I need to do for the 0441 evap purge flow?
Old Jul 16, 2009 | 09:36 AM
Talk to your mechanic.
Do not let him rebuild the drive shaft if he has never done a double cardon and don't let him remove the intake manifold to replace the wires, it can be done with out and for less money.
Old Jul 16, 2009 | 12:16 PM
tornado_735's Avatar
Wait a second...aren't wires 1 and 6 on the same coil pack?
Old Jul 16, 2009 | 01:35 PM
lipadj46's Avatar
Here is the diagram for a DII
Old Jul 16, 2009 | 01:51 PM
jycsalas's Avatar
That diagram is out dated. See if you can tell the difference in this one.
Old Jul 16, 2009 | 02:10 PM
lipadj46's Avatar
How is it outdated?
