SES Light
Had an issue back in the fall with the SES light and it was giving me the lean bank codes, don't remember exactly the numbers, and I assumed it was the MAF. I went against advise and cleaned it figuring if it was bad I couldn't do much more damage to it. The light stayed off for a while but came back on today. Checked the code and it was the P0734 Gear 4 ratio incorrect code.
Should I assume the MAF is finally dead, should I check anything else before replacing the MAF?
Also, where is the best place online to get the MAF; Atlantic British is 220.
Disco_Fever
Apr 26, 2011 11:59 AM
