SES Light
Old Jan 18, 2012 | 12:39 AM
Kalel's Avatar
Default SES Light
I had the SES light come on and had a Malfunctioning O2 Bank 1 Sensor 1, and a Bank 1 lean. So I replaced all 4 O2s, they had 92k on them, and guess what? Same codes again. I am thinking a Vac leak somewhere.
Old Jan 18, 2012 | 06:47 AM
tee51397's Avatar
Try clearing them again and see if they come back, it does sometimes happen.
If it does come back check for exhaust leaks, a Seafoam treatment is a great way to find even the little ones.
If no exhaust leak it's either the valley gasket or a slight possibility of injector o-ring. The lower inlet manifold bolts have been known to loosen over time and often just a re-torque will solve the issue. A can of carb cleaner can be a great tool for finding vac leaks.
Old Jan 18, 2012 | 06:48 AM
Give us the exact fault code numbers so we know what failed with the 02's.
Have you cleaned all 4 connections, grease or oil will cause them to throw codes.
Old Jan 18, 2012 | 09:52 AM
Kalel's Avatar
Yeah, cleaned them up, and the codes were: P130 and P171. Found a slight Exhaust leak at the Manifold flange on the drivers side. Could that be the problem?
Old Jan 18, 2012 | 10:07 AM
tee51397's Avatar
Definitely and bank 1 is the LH so looks like you found the issue!! Those always leak for some reason. The good news is that it's a cheap and quick fix.... assuming you don't twist off a stud, so be careful with that.
Old Jan 18, 2012 | 10:44 AM
Kalel's Avatar
Twisted off a stud. Exhaust repair kit coming up.
millejdq
Jan 9, 2023 10:46 PM
pjvarc
Aug 5, 2011 04:23 PM
Disco_Fever
Apr 26, 2011 11:59 AM
morfa
Oct 27, 2006 10:43 PM
rdisco2
Sep 21, 2005 01:12 AM
