Setting brake pads question
Old May 6, 2016 | 07:52 PM
jamieb's Avatar
Default Setting brake pads question
So I wasn't really thinking and installed the front rotors and pads only today. Did the drive where I went from 40-10 5 times then 35-5 5 times etc. problem is I am doing the rears tomorrow and have to repeat the process.
A) can I do the rears after just bedding the fronts? So soon?
B) wait a couple hundred miles and then do the rears to bed them with hard stops?
C) instructions say I can drive normally after the bedding so maybe it's ok to repeat the process again?
Advice please.
Old May 6, 2016 | 09:57 PM
mln01's Avatar
You're overthinking this. Go ahead and do the rears.
Old May 6, 2016 | 09:59 PM
Charlie_V's Avatar
I've redone my pads a few times. I just get in and go. Don't worry about it.
jamieb's Avatar
I think the fronts do the most work. I agree with you. For some reason I was thinking once you bed the pads you can't hard brake for a couple hundred miles. Thanks.
Old May 6, 2016 | 10:00 PM
Charlie_V's Avatar
We posted at the same time. They'll be fine Jamieb.
And congrats for all of the work you have done on your Rover recently!
Old May 6, 2016 | 10:03 PM
jamieb's Avatar
Thanks! Doing the brakes because I think the last rotor turn thinned the fronts enough to shimmy.
Went with the new ceramic pads and slotted and drilled rotors.
Hope to take a break from repairs for a while. :-). I'll make my way to your neck of the woods maybe this summer to say hello. Thanks to all here for all the tips
Old May 6, 2016 | 10:08 PM
Charlie_V's Avatar
Originally Posted by jamieb
Thanks! Doing the brakes because I think the last rotor turn thinned the fronts enough to shimmy. Hope to take a break from repairs for a while. :-). I'll make my way to your neck of the woods maybe this summer to say hello. Thanks to all here for all the tips
You and me both! I'm close to a reliable vehicle. Maybe I'll get there tomorrow when I take the whole thing apart again.
There is a great place in Gilmer, Texas that has mild to medium trails and I have always wanted to do the whole Kiamichi trail. There are so many Texas people on the forums. Maybe someday. Anyway, I'd love to meet and both rovers be behaving at the same time.
Old May 7, 2016 | 10:36 AM
jamieb's Avatar
Rear rotors and pads installed this morning. Bedded them in. All seems well.
Old May 7, 2016 | 12:52 PM
DiscoBuckeye's Avatar
I would love to live in Texas!...well all except for the Buckeyes being here.
Old May 7, 2016 | 02:08 PM
Charlie_V's Avatar
Plenty of Buckeyes here, Buckeye. In fact, the Gilmer mascot is the Buckeye! Hahhaa. There is a large Ohio expat community here.
