Shaking rear from 1st to 2n gear automatic 2004 d2
Old Aug 16, 2015 | 10:44 PM
itiosso's Avatar
8th Gear
Angry Shaking rear from 1st to 2n gear automatic 2004 d2
Hey guys so I just installed a lift kit terra firma 2in and on the way home from my buddy's house I have noticed that after 25m or so driving when pulling out from a red light there was some shaking coming from the rear end when going from 10-15mph to about 20-30mph during gear changes. I was able to simulate the same behavior when manually selecting 1st gear and then moving 2nd.
The vibration did not occur on every single try. Maybe it was at a different rev idk.
Anyone knows what the heck?
Old Aug 17, 2015 | 01:43 AM
jfall's Avatar
You probably got a lot more wobble in the truck frame vs body now?
Guessing.
The gear change makes the truck frame and body wobble as compared to each other
and that puts the drive shaft at an angle where it may have the universal joint too far at an angle from drive shaft to the rear hub.
Just a wild guess but...
Old Aug 17, 2015 | 09:31 AM
Charlie_V's Avatar
Another wild guess here... check your rotoflex (rubber at back of rear driveshaft). If it was marginal when you did the lift it might be sub marginal with the new angle. Easy fix if that's it.
But I think a marginal joint at front is a better guess.
When I did a 3 inch TF lift, my formerly happy front driveshaft of thirteen years began a rapid death spiral, so the new angles can cause issues for older shafts.
Old Aug 17, 2015 | 09:46 AM
drowssap's Avatar
check ujoints and rotoflex as suggested
Old Aug 17, 2015 | 11:00 AM
Racer X's Avatar
Maybe you're mistaking the rear end shake for what sounds like transmission shudder between shifts?
Because that sounds a lot like a transmission shudder between shifts.
Old Aug 18, 2015 | 04:57 AM
OffroadFrance's Avatar
Could possible be Watts linkage bushes failing now eccentuated by the extra lift or maybe the shaft Rotoflex binding due to extra lift. It might even be radius arm bushes failing.
Old Aug 19, 2015 | 05:31 AM
itiosso's Avatar
8th Gear
So I have noticed that the shudder doesn't happen all the time. Truck drives and shifts normal if not put to extreme RPMs or above 70mph.
I believe it has something to do with the front prop and the rear rotoflex.
I am replacing the front shaft in the next few days and placing an order for a rear shaft with the conversion kit.
Should have both installed and all the fluids in the driveline replaced within a week.
Just got this truck so I don't really know what has been done to it. Rather not take chances.
Will post back with results when the parts are all in.
Thanks for the great feedback.
Oh btw, has anybody done any adjustment or removed the front shaft cross member? It really takes some clearance of the front if at full flex (although front will hardly ever need the full flex I believe) I am currently studying spacers or get a fab company to just cut it off and move the shaft section down 2 inches.
Old Aug 19, 2015 | 10:42 PM
itiosso's Avatar
8th Gear
Default So what can I check?
So, yeah, that sounds pretty much what i have been going through. Would you mind clarifying? Like, is it normal? Is there something about to go? what to look for? how to fix it?
Much appreciated.
rcrosby
Apr 7, 2017 12:19 PM
Rover Newbie
Jun 25, 2015 07:03 AM
Trond Asdam
Jun 26, 2013 01:11 PM
jfall
May 16, 2012 08:08 PM
LxR
Oct 24, 2007 04:01 PM
