Shaking steering wheel at 40+ mph
Old Dec 30, 2007 | 05:10 PM
LRDISCO's Avatar
Default Shaking steering wheel at 40+ mph
I just put new tires on my disco theyre 29x10.50x15interco trxus AT tires and now when i'm driving the steering wheel shakes very badly after 40 mph. It did this before when i had my steet tires on but now its really bad. I bought an OME stabilizer to try and help but i was shipped the wrong one. Would the stabilizer help that much? Or do i need a front end alignment??
Old Dec 30, 2007 | 05:18 PM
jkid's Avatar
Default RE: Shaking steering wheel at 40+ mph
I would get the alignment done first. You should really have it aligned when you put on a new set of tires (assuming it's been a while since it was last done). You don't want to ruin those brand new tires.
Old Dec 30, 2007 | 05:54 PM
okdiscoguy's Avatar
You will notice a good amount of difference with the new stab.
Were the wheels new? If not, have they been checked for straightness???
Old Dec 30, 2007 | 06:33 PM
Alignment on a Rover is a toe setting only which will not cause this problem. Thats not to say a tie rod or bushing is not causing it. Yes the new OME stabilizer will make a big difference but you need to correct the problem also.
Old Dec 30, 2007 | 07:03 PM
LRDISCO's Avatar
Thanks for all the replies i will be getting it aligned and i will be returning the Stabilizer and getting the correct one.
Old Dec 30, 2007 | 08:44 PM
geotrash's Avatar
Tire balance ora bent rim are the most likely culprits. I've had several shops screw up the balancing on new and old tires in the past. You might take it back to them, describe the shimmy and ask them to rebalance the tires and check therims for sraightness.
Dave
Old Dec 30, 2007 | 08:46 PM
LRDISCO's Avatar
I put all thewheels on the truck myself i just had a tire shop put the tire on the rim and balance them. and the rims are brand new so they arent bent.
Old Dec 30, 2007 | 09:48 PM
05LandRover's Avatar
did the wheels get balanced after the new tires were on?
Old Dec 30, 2007 | 10:22 PM
LRDISCO's Avatar
yes the wheels and rims were brand new when mounted and they were balanced.
Old Dec 31, 2007 | 08:31 AM
I had seen too many times when a brand new wheel was bent, just keep it in mind.
