shelf, under driver's seat, on frame, what is it for?
Old Aug 6, 2013 | 01:42 PM
earlyrover's Avatar
Default shelf, under driver's seat, on frame, what is it for?
On my 2004 Discovery, below the driver's seat, welded to the frame, is a shelf like three sided box affair that is obviously there for a reason, but what is the reason?
Old Aug 6, 2013 | 02:30 PM
schwaggy's Avatar
Possibly the mount for the HK audio amplifier?
Old Aug 6, 2013 | 02:34 PM
cosmiccharlie's Avatar
I think he means on the frame of the truck. SLS air compressor would go there if your truck was equipped with SLS.
Old Aug 6, 2013 | 02:39 PM
coors's Avatar
Correct. That's where the compressor sits if you have SLS. Mines disconnected. Want it?
Old Aug 6, 2013 | 03:50 PM
Red_Liner740's Avatar
Not just the compressor, the whole shebang
three relays, filter and compressor.
Old Aug 6, 2013 | 06:54 PM
drowssap's Avatar
there is someone in the WTB section looking for that stuff
Old Aug 6, 2013 | 09:15 PM
FlyingZebra34's Avatar
I was thinking about putting an on board air compressor there for air in up the tires after wheeling
Old Aug 6, 2013 | 10:11 PM
bosshogt's Avatar
Save your money for a PowerTank, I go wheeling about every other weekend in Colorado. I picked up a 10lbs Powertank on CL for $130. Plus you can run numatic tools on the trail, and blow out your messy cargo area. You always have air and its about $16 to fill up the CO2 tank. Any company that services fire extinguishers will refill your tank for a deal. I have filled my tires up from 20psi to 40psi about 6 times on a half tank.
Old Aug 6, 2013 | 10:16 PM
What if you ran a compressor to fill the tank?
Old Aug 6, 2013 | 11:21 PM
bosshogt's Avatar
The tank is filled with liquid Co2. Same thing that carbonates Coke. The tank when pressurized will run about at 160psi, so plenty of flow for power tools and you can fill all 4 of your tires up faster than your buddy with the Via Air compressor can fill 2 tires. The Powertank has a regulator on it like a scuba tank...so you can control the air pressure once the main valve is open.
