shepard stop leak
Old Jan 23, 2012 | 08:36 AM
drowssap's Avatar
Default shepard stop leak
what it the actual name of this stuff and where are you getting it?
Old Jan 23, 2012 | 08:39 AM
White Shepherd - here's a store locator Locate a store near you that carries our stop leak products | USA SEALANTS | Stop Leak for Oil Leaks, Blown Head Gaskets, Transmission & A/C Leaks
Old Jan 23, 2012 | 08:57 AM
drowssap's Avatar
thanks
Old Jan 23, 2012 | 09:12 AM
Which of their products are you looking for? If you can't find the right one, go to
gouniversalproducts.com
Old Jan 23, 2012 | 09:16 AM
94svt50's Avatar
Those who have used white shepard in their land rovers, what has been your experience, success rate with this product?
Old Jan 23, 2012 | 09:26 AM
First of all, they make 8 different products.
I have used their oil stop leak in both my t/case and rear diff with great no more leak results. I have used theit p/s stop leak over a year ago and as long as it is not a hose leak it will stop leaks in the p/s pump as well as the gear box. They make a great rear main sealer that I have seen used with pretty good results. I have not used either of their a/s stop leaks and tell everybody to not use the Blue Devils coolant stop leak, it is a terrible product.
hilltoppersx's Avatar
i refuse to use it... just fix what is wrong rather than use some product to try and correct it.
Old Jan 23, 2012 | 09:28 AM
That is always an option, curious though, why, especially if you have never used it?
Old Jan 23, 2012 | 09:41 AM
0304Disco's Avatar
I used the rear main seal stop leak with no success. It sure was worth the $13 gamble which could have saved me from yanking an engine again.
Old Jan 23, 2012 | 09:46 AM
drowssap's Avatar
looking at the rear main seal stop leak for my wife 3.9, to cold & to lazy to be pulling a motor in January
