shepard stop leak
Old Jan 24, 2012 | 04:37 PM
  #21
hunter's Avatar
Originally Posted by Disco Mike
For that head gasket leak, never use a form of coolant stop leak, especially the Blue Devil, it is the worst of the bunch and will turn into gel in your coolant system and gum up everything.
Is there a non-coolant stop leak you might recommend for a head gasket? Otherwise, per my response to Ed, I'll just keep an eye on the current level of seepage. No coolant loss, though I did just have to replace the throttle body heater, and no noticeable oil loss, just wetness at the gasket.
Thanks,
Dave
Old Jan 24, 2012 | 04:43 PM
  #22
hilltoppersx's Avatar
nothing will stop it. you can check the bolts see if they worked loose but other than that you will need to replace the gasket. i had mine fail horribly on my way home from the city lost power cel came on and the gasket was shot just pumpin coolant into the oil.. nothing u can do at that point but tow it.
Old Jan 24, 2012 | 05:19 PM
  #23
hunter's Avatar
Well, good thing I have the AAA 100 mile tow coverage, though will probably opt for taking the wife's Pilot to the mountains.
Thanks, Ed.
CapeRover
May 3, 2013 04:35 PM
CarolynS
Jun 11, 2011 03:31 PM
Spike555
ROAMING WITH FRIENDS
14
Mar 20, 2011 09:37 AM
discoboy
Oct 8, 2010 11:55 PM
