Shift Indicator Fix?
RE: Shift Indicator Fix?
There is a shift tape replacement, but I haven't seen one in a while. www.roverconnection.com used to have them. Might be dealer or salvage only on this one. If you pull the shift handle and transfer handle, you can pull the center console and get to the shifter assembly. The tape wraps around the shifter to display the gear selection. There is a rind and plastic ball that attaches to the shifter handle.
Best bet is to find someone parting one out that still has a good one. I found a guy that just threw it in with some other parts.
importdave
09-25-2014 10:18 PM
