shock choice
OEM length should be fine. The shock mount is actually raised in the front with a spacer. The rear will not be raised, but it's just an inch so you'll be fine.
Biggest tire you should try to fit will be a 32", you might be able to fit a 33" with some work. I've got 265/65/18s on mine at stock height, which is essentially a 32". That would be a 265/75/16 if you have 16" rims.
ellebarto
Sights N Sounds
05-21-2013 09:35 AM
