Should this hose be here????
Old Feb 5, 2019 | 04:13 PM
bcurtman's Avatar
Default Should this hose be here????
i did the FV308 PCV mod from the intake to the passenger side valve cover. Went as planned. Assume it works as intended. I've been eyeballing this hose since I had to remove it to take the upper IM off for the coil job. It also runs from a nipple near where the hose from the air filter assy slips onto the upper manifold and runs to a fitting of some sort in the drivers side valve cover. Stock? If not, what should be there?
Old Feb 5, 2019 | 04:14 PM
Saturnine's Avatar
That’s supposed to be there
Old Feb 5, 2019 | 04:31 PM
CollieRover's Avatar
It's a breather tube, and should be there.
Old Feb 5, 2019 | 04:35 PM
bcurtman's Avatar
So, no pvc valve required on that one? Or should / can I double up with the FV308 there as well?
Old Feb 5, 2019 | 05:12 PM
JUKE179r's Avatar
Do NOT put a PCV valve there unless you really want to blow out a rear seal.
Old Feb 5, 2019 | 05:45 PM
Extinct's Avatar
PCV valve is on the manifold side of the throttle body, it controls the flow of crankcase gases in to the engine while the engine is a closed throttle high vacuum conditions. In open throttle low vacuum conditions that breather tube routes the crankcase gases in to the engine without the PCV restriction. The wikipedia page on PCV is actually a pretty good explanation of the design and history of PCV systems. The breather tube should not be modified.
Old Oct 8, 2019 | 01:28 PM
britguy's Avatar
I found this
Shows how flow should be
evoblade
Mar 13, 2016 04:31 PM
sobieski
Nov 3, 2015 08:08 PM
grandkodiak
May 8, 2011 06:44 PM
Phototone
Apr 5, 2008 02:25 PM
rravenn13
Jul 19, 2007 01:33 PM
