Should I buy a used 2001 Discovery?
Old Dec 8, 2006 | 03:40 PM
phia@binoco.com's Avatar
3rd Gear
Default Should I buy a used 2001 Discovery?
Looking to buy a used 2001 Land Rover - Discovery - Should I do it? What are the pros and cons?
Old Dec 8, 2006 | 04:07 PM
geoman's Avatar
Default RE: Should I buy a used 2001 Discovery?
The Disco II has been received well by those having prior experience with other Land Rover models. However ---like any other Land Rover, the upkeep and servicing of this vehicle--- in strict accordance with the factory recommendations--- is crucial. Don't buy one without service records, or be prepared to throw the dice and hope. Read my tech info sections at www.eurotekapg.com to give yourself some knowledge on what to look for when checking out a used vehicle.
A couple of things that come to mind on the Disco II---- If the mileage is 60K or higher make sure the serpentine belt, tensioner, and idler pulley have been replaced. Water pumps can sometimes start weeping arounf the 60-80K mark, so check for signs of coolant leaking. The throttle body heater plate (under the entry snout of the engine air intake plenum) will sprout a leak, and dumps coolant on the left valve cover (as viewed from inside the vehicle). Easy fix with a kit I can provide.
Anyway-- best of luck in searching out a good one.
They are awesome vehicles for the informed ----- pains in the *** for those that think they can drive them with the level of non-involvement typically seen by drivers of Asian vehicles.
regards,
Geoman
eurotek apg
"serving the do-it-yourself Land Rover owner/enthusiast"
Old Dec 8, 2006 | 10:19 PM
What are you wanting to do with this truck?
Mike
stevobentz
Oct 1, 2012 06:54 PM
ewok
Apr 5, 2011 02:49 PM
andetechinc
Jul 16, 2010 06:42 AM
Classklown90
Oct 10, 2009 08:40 AM
DocSean
LR2
Jun 26, 2008 07:39 AM
