Should I be concerned (Engine temp)
Old Feb 1, 2017 | 08:48 AM
Best4x4's Avatar
The OEM thermostat never just opens and then stays open it will open/close constantly. That is why if you monitor the temps you will see a "cycle" from cool, warm, and back down to cool.
I owned D2's when they were brand new and I can guarantee you they were doing 210-215F right off the showroom floor. I never killed one or did I have any head gaskets replaced. 188-210F is the norm operating range in my book. I'm normally at 188-204F as a range. I wouldn't really worry unless I saw it climb above 210F. Then I would certainly investigate.
Old Feb 1, 2017 | 02:47 PM
number9's Avatar
Originally Posted by Dave03S
In the morning before you start it, open the bleed screw and top it off with coolant. That will remove any trapped air at that high point.
This what I recommend doing after an initial system bleed per the manual. If you do this each morning when stone cold until you can add no more it woks very well. Clean and cuts down on coolant waste. All you need is a small funnel. It's also a good idea to do this occasionally to ensure your system is not getting too much air into it.
ems12
Dec 12, 2014 02:07 PM
dusty1
Off Topic
May 7, 2014 03:28 PM
green_
Dec 15, 2012 11:02 AM
RoverR
Nov 2, 2010 09:11 PM
joatman
Aug 24, 2010 11:36 AM
