Should I stick with Dexcool?
Old Feb 26, 2010 | 10:33 PM
Willie00d2's Avatar
Default Should I stick with Dexcool?
I replaced every gasket and seal in the engine. Should I stick with Dexcool or switch to something else. I head Dexcool is corrosive.
Thank you,
Willie
Old Feb 26, 2010 | 10:53 PM
Mrmerlin's Avatar
I am using Zerex Z05 found at NAPA
Old Feb 26, 2010 | 10:58 PM
hilltoppersx's Avatar
i recently switched to Peak Global...
Old Feb 26, 2010 | 11:33 PM
elboy0712's Avatar
Hmm dont have my manual right here but is it dex in all disco's or just D2's and beyond...
Old Feb 26, 2010 | 11:58 PM
NiteTrain's Avatar
nope, i'd change to something else
Old Feb 27, 2010 | 12:09 AM
elboy0712's Avatar
well mine is a series I thats why I ask ... but no big deal i am off in 30 minutes anyway .. ill check it out...
Old Feb 27, 2010 | 12:49 AM
discoboy's Avatar
I have read enough bad stuff about Dexcool, so I switch to G05 coolant when I did the headgaskets on the 2000 Disco, and will do the same with the 2003 when I do the headgaskets on that one. I figure if it is good enough for Mercedes to use its good enough for my Rovers.
Old Feb 27, 2010 | 12:55 AM
AK Rover's Avatar
No isn't quite the right word so I'll go with HELL NO you don't want to stay with Dexcool. It turns to acid and damages your engine and cooling system.
Old Feb 27, 2010 | 07:17 AM
lipadj46's Avatar
Dex is fine engines that don't leak or if you flush your coolant regularly. Personally I like G05 or old fashion green coolant. The universal coolants are fine too (prestone, peak) but they are similar to dexcool.
Old Feb 27, 2010 | 07:29 AM
they are similar but the Peak Global substitutes a different organic acid for 2-EHA. 2-EHA is in Peak Lifetime and Dex-cool and is known to destroy!
