shut down
Old May 14, 2015 | 08:04 PM
mikep70's Avatar
6th Gear
Default shut down
I have a 2001 discovery that I can't get into. My key first of all will not open the driver's side door, and the remote is broken. I had roadside service to try and get in but they all failed. I called Land rover and they said that the car is in super shut down mode. I tried going through the window with a rod to push the unlock button but it won't work. Finally I was told that if a new key didn't work I'd have to break the window. Well my window is broken and I still can't unlock the car. I pull up the door lock and it snaps back down. has anyone ever experienced this??? What can I do? The dealer wants to charge $992 to replace the door handle. Can someone help???
Old May 14, 2015 | 09:18 PM
coors's Avatar
Unfortunately, you are experiencing what Land Rover calls "Superlock". The only way in is, breaking a window.
I'm not familiar with this feature, run a search and I'm sure you'll find a ton of info. Or just hang tight and someone will offer advice on next steps.
Old May 14, 2015 | 10:18 PM
mln01's Avatar
Coors is right - search for "superlock" or "superlocking" and you should find the info you need to correct it. It may not be inexpensive given that you don't have a keyless remote but a grand ($) seems like a lot to pay.
And when you're ready to replace your window let me know; I have an extra I need to sell.
bevi1970
Oct 31, 2011 03:27 PM
0304Disco
Jul 20, 2011 05:28 PM
nmgirl
Dec 13, 2010 09:30 PM
montez27
Aug 22, 2010 01:11 PM
Mountainman
Defender
Jul 27, 2007 06:54 AM
