Shutoff while off road
So I tried to climb a steep hill today in low range. I got close to the crest and one of the front wheels came off the ground, so I backed out before it rolled over. Even with applying some brake, I rolled back down the hill pretty fast since it was so steep. It was still in low gear in drive. When I got to the bottom it had shut off. It took a couple abnormally long cranks to get it going again. No CELs or anything else though. Ran fine the rest the day. So what happened? My guess is either the engine got revved to high by being in low that the cpu couldn't keep up with fuel, or the transmission did a safety shutoff since it was in drive and moving so quickly backwards. Any thoughts?
No fault codes and runs fine now. It had over 3/4 of a tank. It did act like a fuel starvage after though. It took two long cranks to get it going, then it was stumbly for a second on idle. I revved it a few times like an old carb engine (which i know doesn't matter with efi) and it was fine. So I kept calm and rovered on .
The engine was still trying to move you forward but it was overruled by the weight of the truck and the wheels turning the transmission backwards.
If you were going fast enough you would have even spun the engine backwards and thats why it was hard to start and sputtered for a min or two.
If you take a auto trans car, drive it over 50mph, shift to neutral, shut the engine off, turn the key back on, drop it back into drive, the engine will start without using the key.
I've done it before on several cars when I was a kid.
You stalled it by going backwards while still in drive.
