Shuttle Valve replaced and...then...
Old Jan 25, 2019 | 05:09 PM
Philip Chan's Avatar
My Mistake. No ABS codes/ability to read ABS on my Autel. I will check with a compatible model and report back.
BTW - I have a feeling that my ABS doesn't work. With stopping suddenly there should be a rapid "tat-tat-tat" like the other ABS systems. I don't think I get this at all.
Old Jan 25, 2019 | 06:22 PM
Best4x4's Avatar
ABS/TC/HDC is disabled whenever the 3 Amigo’s are stored in the SLABS memory.
Old Jan 28, 2019 | 08:51 PM
garrddogg's Avatar
Originally Posted by Externet
Hi. am very interested in the comment that a failure in the printed circuit board triggers the 3 amigos. Is there any post reporting such that I can look at ?
Diagnosis of my ABS unit tells me it is doing what it should, connected oscilloscope to each wheel speed sensor (while driving) and the correct and healthy signals are being fed to the compfuser input connector.
Is the ABS control board mated to the serial number of the ECU, in such way that replacing it will not be recognized and cause more trouble if not 'christened' ?
https://landroverclubvi.weebly.com/abs-mod.html
Old Feb 4, 2019 | 06:38 PM
Managed to get a scanner that reads ABS.
Shuttle valve electrical fault is the code...
Old Feb 4, 2019 | 08:07 PM
Best4x4's Avatar
Did you clear it with that tool? It should stay off unless you still have an issue.
Old Feb 4, 2019 | 08:08 PM
Yes - it cleared and hasn't returned.
Yet.
Old Feb 4, 2019 | 09:17 PM
Best4x4's Avatar
Well since you replaced the Shuttle Valve Switches you should be good to go unless the internal connection inside the WABCO Unit is failing. Then simply perform Option B and you'll be good to go after that.
Old Feb 14, 2019 | 11:35 AM
It returned...of course. I scanned it's the same fault.
Will attempt Option B sometime...
Old Feb 14, 2019 | 12:41 PM
Best4x4's Avatar
It’s a simple job
Setflyn41
Mar 12, 2019 07:29 AM
Friday Night Disco
Feb 4, 2017 06:05 PM
Externet
Dec 17, 2015 09:53 PM
redrover75
Nov 23, 2014 04:43 AM
