Side mount jerry can mount for Discovery 2?
Old Jul 26, 2020 | 02:57 PM
dcaven's Avatar
Default Side mount jerry can mount for Discovery 2?
I really like the concept of this mount. It is for a Defender. It seems like something similar could be done for the Discovery. An aluminum horizontal bottom attachment rail could be riveted to the body. Would present an issue on the right side for filling the tank but would not be that big of a deal. I would like to carry extra gas but would like the weight lower than the roof rack.
Old Jul 26, 2020 | 03:41 PM
Richard Gallant's Avatar
I carry mine inside in no vent cans, the 1st day you should ease the pressure generated by heat but that is it. In 9 years I have not had a leak or gas fumes. I carry 40 liters where teh 60% seat used to sit.
Old Jul 26, 2020 | 05:19 PM
Art H's Avatar
I do not know about side mounts, but I have seen ladder mounts for jerry cans
Old Jul 26, 2020 | 05:53 PM
I would rip those off on a tree lol
Old Jul 27, 2020 | 02:54 AM
The Deputy's Avatar
Yeah, in the back keeps it out of harms way. Well above rear impact level...unless a semi or something...but if that's the case...what's a little extra flames...lol.
Old Jul 27, 2020 | 03:00 AM
The Deputy's Avatar
Yep, wider...or higher sometimes causes issues...
But l put Chris to work on it...lol.
Old Jul 28, 2020 | 10:15 AM
whowa004's Avatar
best answer is on a spare tire swing out to avoid adding more weight to the back door. But those options are extremely limited/costly unless going the custom route.
Old Aug 1, 2020 | 07:33 AM
dcaven's Avatar
You might consider driving a bit slower.
Old Aug 1, 2020 | 07:38 AM
dcaven's Avatar
You are correct. I am almost 100% certain I will go with a rear mount option instead. I'm just exploring the idea. A rear mount will keep them even lower than a side mount. I deeply dislike rooftop mount options as they add so much weight up top and are much more likely to get in the way. I want to add several cans, however, combination of fuel and water. Do you know where I would find data as to how much weight the door hinges can safely handle? The spare will be going up top. Thanks.
Old Aug 1, 2020 | 07:40 AM
dcaven's Avatar
A good chainsaw will fix just about anything! Point taken. I'm now focused more on a rear mounting solutions. I still think the side mounts is a better idea than roof mounts. Rear mount is likely by far the best option.
